How to get elements by view
    Normally get elements by view should write as follow:
    FilteredElementCollector coll = new FilteredElementCollector(m_document, view.Id).WhereElementIsNotElementType();
    But I found if invoke this statement will consume so much memory as a result if loop every views to get elements will consume so much memory. But if I get elements by document as follow:
    FilteredElementCollector coll = new FilteredElementCollector(m_document).WhereElementI sNotElementType();
    it will consume almost no memory even I invoke it at every views. Anybody know why.
    if it is bug. and I think I should get all elements by document firstly. then classify those elements by views. But now I don't know how to know which elements belong to (or are visibly to ) which views. It sees no method to classify it. Can anyone help me. thx
    If you want to start with the big list, you can use the Linq namespace
    See Enumerable.GroupBy(TSource, TKey, TElement) Method (IEnumerable(TSource), Func(TSource, TKey), Func(TSource, TElement)) (System.Linq)
    After you get the list of Elements, try something like this:
    Code:
    IEnumerable<IGrouping<View, Element>> query = list.GroupBy(e=> doc.get_Element(e.OwnerViewId) as View, e => e);
    PS: I haven´t tested it
    Gonçalo Feio
