is there anyway of getting the grass to look somewhat more realistic than the current images in revit?
rendering grass
And crank up the rendering settings a LOT.
This is doable, but will give you a looooooooooooooong coffee break. Trust me, I tried.Martijn de Riet
Playing around with your bump map can help too.
It's too bad that you can't assign noise & multiple bumps to textures :crazy: - that would help immensely. If you have 3DSMax you can drop everything in to it and render there.
You can also create grass objects and populate your landscape with them depending on your camera angles. The following was done with SU in mind but the same principles apply:
SketchUp and Vray Resources: Tutorial: Grass and Rock Displacement in Vray SketchUp
TwilightRender.com • View topic - Need Grass?
Ah, ok in other softwares it`s easy. In revit is interesting to see the best grass achieved.
Here is some in rendered in 3DMax/mentalray(attached).
Or in the test about rendering benchmark http://www.revitforum.org/hardware-i...benchmark.html
(where almost nobody has been interested)
Originally posted by gaby424 View Postnope. 3D Max with grassomatic plugin.Martijn de Riet
Originally posted by joewallace View Postis there anyway of getting the grass to look somewhat more realistic than the current images in revit?Klaus Munkholm
👍 1
I've been messing around with rendering on and off for a year or two. Attached are two renderings. Both are 150 dpi 4" wide. One is done on the medium...
Channel: Rendering and Gallery
June 10, 2011, 03:43 PM -
I have Dell T1500 Workstation with following configuration.
Intel i5
4GB Ram
Windows 7 Pro 64bit.
1GB Quadro600 Graphics...-
Channel: Hardware and Infrastructure
December 5, 2011, 03:32 AM -
Hi, I have to render a mountain (and insert a bridge in it) and can't achieve a good result with Revit texture's... it never looks realistic: a mountain...
December 20, 2010, 02:53 PM -
We've been using revit to make quick renderings of projects which works fine. We now need a high resolution rendering to be used on a construction site...October 8, 2018, 01:00 PM
Hello, producing this rendering but not satisified at it. (still using revit 2008 to modelled and render). how can i make it look more realistic? is it...
October 25, 2016, 05:51 AM -
Monumetric Footer In-screen
