Groups - CAD Export
    Groups - CAD Export
    When we export a file that has groups, is there a way to make the groups export as a block or an xref?
    Thanks!
    ~Elisa
    BIM Director, AC Martin
    Sorry, as far as I´m aware of, that´s just not possible.
    Now, where´s that wish list?? Maybe we should ask the admins to create one? Ohh... wait... :beer:
      Thanks! I was afraid of that answer... and yes this is definitely on my wish list.
      ~Elisa
        Couldn't you export in two stages: first save all groups to different files, reopen and export to dwg.
        Then, use a filter or manually turn off all groups in the file and export that.
        If you open the main file in autocad you can insert the groups as a xref.
        Maybe this is too much trouble for what you're after but that's the only solution I can think off.
          What about worksets? Is there a way to assign them to a workset and then just export each workset?
          Juan Carlos Moreno
          Sisley Cosmetics
