I've got a survey that came with a high-resolution aerial photo, properly aligned with the CAD data. Is there any way to import the aligned aerial into Revit?
Is it possible to accurately import an aerial that comes with a DWG survey package?
Possible, yes. Easy, no.
First, the image will come in at a random scale regardless, so you will need something you can snap too, in your plan.
Second, Revit will automatically downgrade it to 72dpi, regardless. So, youll have to hack it in to pieces, if you want it to look decent.
Third, with the advent of Realistic view, you CAN put it on a Material, using the hi res image... And get some amazing results. Scott Brown (i think?) has some examples in the Rendering forum. I would try that before i would goof around with the above suggestions.
Originally posted by Twiceroadsfool View PostThird, with the advent of Realistic view, you CAN put it on a Material, using the hi res image... And get some amazing results. Scott Brown (i think?) has some examples in the Rendering forum. I would try that before i would goof around with the above suggestions.Mark Balsom
Hey!
Anyone ever tried to import a LandXML from the survey of an existing road?
The main problem i see is that the curve is...-
Channel: Structure - Interoperability
November 19, 2012, 01:16 PM -
Somehow, I did this once before. Although the results were less than adequate, at least I could do it. Unfortunately, I did not keep notes on how I did...April 24, 2012, 05:29 PM
Hey all,
Having some fun with setting up a survey in revit from a supplied survey dwg. This has coordinates which reference the Perth coastal...February 11, 2014, 04:30 AM -
I am linking in a raster image. It is all set up to be able to be imported at 100% horizontal and vertical scale. These values are not changeable. ...March 24, 2011, 08:25 PM
Hello,
I'm working on a project and I'm coming from the field of geodesy. I have following problem:
I have a dwg file of a builing which...-
March 7, 2018, 10:32 AM -
