Rooms in Groups - Error
We are using groups for apartment units in a multifamily housing project. We have rooms within these groups and we use the room name value to tag our units with the unit type. When trying to rename the room, we're getting a "Cooresponding group members in different groups diverge in the following respects: - different positions relative to the group origin" error. The error references the model group and the room.
I've tried to fix groups and create new group types, but then I am unable to switch it back to the original type. I also tried deleting and replacing the room object, but I get the same error. The only fix I can come up with is to delete the 2 problematic instances of the group from the model and replace them.
Has anyone run into this before? I've run into the same error with families causing the problem before, but never rooms.
I have several groups that contains 1-5 electrical fixtures and/or data devices. They are all level based.
If I turn off room bounding on...-
Channel: MEP - General
December 5, 2016, 08:54 AM -
Hi all,
We are having an issue with some groups. We are doing a large project with a ton of repetition for ensuites , bathrooms etc so we have...April 9, 2014, 01:31 AM -
So we've had problems with groups before in Revit 2018, but never been able to replicate the error.
Now i have the perfect study example;...August 21, 2018, 08:25 AM -
I have a number of typical room layouts for an assisted living facility that are groups and I keep running into issues when I need to modify them. The...December 27, 2012, 02:51 PM
So I've been following a thread about high-rise buildings and groups. Now, I've not done much with groups, at least partially because I've not worked...January 6, 2020, 09:21 PM
