Problem with printing sheet sets ?
  • mark b
    Originally posted by Sputnik View Post
    Mark! Thank you very much. Installed a PS driver, and it fixed it
    No worries, I suffered for months and spent countless hours trying to find a fix, you are very lucky you came to the right place !!
    Another satisfied customer. :laugh:
  • Sputnik
    Originally posted by mark b View Post
    Its a driver issue. Had this problem before and with a lot of searching the fix was loading a PS (postscript) driver for your printer. Believe me it works, i went through months of heartache and the the fix was simple. :banghead:
    My issue was with HP printers, but should be the same for most printers.
  • mark b
    My issue was exactly as Sputnik described printing straight out of revit to paper. Printing to pdf was fine. Had the same issue on 3 different HPs of different models in 3 different locations and the postscript driver fixed the issue even though they were not postscript printers.
  • mdradvies
    Is this printing to pdf, using a different software, or printing on paper? I have never heard of this problem before... But it does sound a bit like something I've seen happen in a dwg-export with bad settings.
  • mark b
  • Sputnik
    started a topic Problem with printing sheet sets ?
    I´m having a very anoying problem with printing selected sheets. Usually the first sheet of the selected set prints fine, but the remaining sheets have boxes around text in gridheads and numbers in dimension lines. Also, objects that are set to halftone are ignored and just printed in black.
    Any suggestion? Thank you.
    PS. This does not occur when printing to PDF with Adobe PDF
