Section Boxes with options
    BS"D
    Does anyone know if there is a way to use a section box in a way that will cut one family but not another? So for example, a section box that doesn't cut topography so that when you are creating axo plans of a building on a slope, you see the building being cut but the entire slope (above the cutline) is visible.
    A section box will cut everything in that view, no exceptions.
    What you are after can be achieved by combining two or more 3D views on a sheet. If the orientation is exactly the same (for instance not changed after duplication) they even line up.
    There must be a better way...
    Ekko Nap
