I have to decrease the width of a gym by 6'-0" that has other rooms connected to a common wall. When I attempt to move all of the elements, I get an error message stating that some elements are restricted to moving in one direction while others are restricted to moving in a conflicted direction. Is there anyway to work around this so that I can shift multiple rooms and elements by the 6'-0" dimension?
Reducing Room Size
Cutting/pasting will blow away any dimensions, tags, etc... Unless you're in SD or early DD that's a last resort.
It sounds like one or more of the elements you are selecting can only move in a perpendicular direction from how you're trying to move it. I'd just start moving things one piece at a time until something threw up the constraints message.
Try expanding the error dialogue box, copy the element ID's to notepad (or something like that) and do a search by ID to see what's going on. Could be you constrained some stuff throughout the building. If this doesn't work, try to cut to clipboard, paste aligned and then move to remove the constraints.Martijn de Riet
Unable to find all Elements in RoomHello,
I am trying to find all-
Channel: Dynamo BIM
August 5, 2019, 04:31 PM -
This is more of a rant than helpful, but since I'm about to throw the computer out the window, figured I'd share...
Probably my biggest...May 20, 2011, 05:18 PM -
Hi Guys, It is me again Revit Crazy and currently i am feeling myself not a RevitCrazy but a RevitStupid.
Here are my questions guys : ...November 7, 2017, 12:25 PM -
When any family is selected we are getting a check option Moves With Nearby Elements, I am not getting what is the use of this opton and
when any...October 17, 2013, 06:21 AM -
Hi, I'm trying to place room names in my project but it doesn't show any blue room delimitation like it does regularly. It's weird because I can see all...June 17, 2013, 11:57 AM
