More than one elbow for one piping system?
    I've been wrestling with an elbow pipe fitting of my own design for weeks now. I've re-made it numerous times; tweaking it every time with another piece of advice gleaned from any hint of tutorial I've found and scrutinized & corrected numerous errors. Perhaps I’m still missing something but all I can assume is that Revit doesn’t like more than one type of elbow pipe fitting to be used in one system run.
    The elbow (attached with look up file) is to be used only on vertical drops on a Hydronic Return pipe line. The Hydronic Supply doesn’t get them.
    Am I using the incorrect family category? Should this item rather be a Pipe Accessory?
    Part Type in Category – am I using the incorrect Part Type? I will admit I don’t know an exceeding amount about pipe fittings and piping.
    Attachments –
    Pdf of what I’m after as per established AutoCAD format.
    Pipe fitting.
    Look up table for pipe fitting.
    Any advice would be most welcome. I’m out of ideas here.
    Ciao for now.
    Say something interesting....
  • Piping system as Pipe fitting family-s
    Hello,
    I´m really confused here with a pipe template that I have received and not sure if I´m the idiot or those families have something...
    February 17, 2016, 08:09 PM
  • Pipe fitting issue
    Hi There,
    I created three different elbows of 30, 45 and 90 degrees and corresponding branches . My requirement is , pipe should be able...
    January 29, 2014, 04:24 AM
  • Pipe Fitting Keeps dissapearing
    I have a pipe fitting that when I draw a pipe to/from it everything is fine. When I connect that pipe into the main branch the fitting disappears. Can...
    June 17, 2015, 11:12 AM
  • Automatic Pipe Fitting - Reduce pipes
    Hello.
    I'm making my own pipes fitting, but i'm having problem with my reducer.
    When I deduce the pipe ø104 to ø79, for example,...
    October 14, 2016, 07:10 PM
  • Pipe Fittings
    I am modelling some pipework on a project and the main corridor has a slight change in angle (approx 2°). This is causing a problem for my pipe run as...
    October 20, 2011, 08:59 AM
