What Revit Wants: Using RDB Link to Tag Wall Volume
    Revit doesn't let you tag Wall Volume by default, so Avisotskiy puts RDBLink to good use - he uses Microsoft Access to update a Shared Parameter with the wall Volume data, and then simply uses a tag to grab the manually updated and manually created Volume data.
    This is not a 'live' link, but it shouldn't take too long to round trip the project to update the Volume information prior to document transmission or printing.
    From his blog:
    Revit does not allow to directly make a mark in the volume of the object.
    4. Unload in Access, using the Query Designer update the "_Obem", taking data from the parameter "Volume".
    via
    Google Translate
    of
    http://avisotskiy.blogspot.com.au/20...t-db-link.html
    Author of What Revit Wants
