Default Detail Item Tag
    I have created two different "Detail Item Tag" annotation families. When is execute the "Tag by Category" command the default one is not the one I want to use as my default. Is there a way to choose which annotation family is used by default to tag a detail item.
    Yes. You can prefefine all the default tags in your project by going to the Annotate Tab > at the bottom of the Tag Category you will see a small arrow pointing down.
    2012-03-08_0801 - Alex_Cunningham's library Click on Loaded Tags, and you can assign the tags to each catagory. http://screencast.com/t/4HTlH1rh3mz9
    -Alex Cunningham
