any way to tell if a crop region has been rotated?
Crop Region rotation?
Originally posted by mark b View PostTrick question ???
The "plan view" will be will be rotated ???I'm retired, if you don't like it, go around!
Originally posted by MPwuzhere View PostCreate a new view...make both in the same direction (ie Project North)...put them side to side and see what you get...
We just learned about the pitfalls of rotating a cropped region at our user group meeting a couple of weeks ago.....I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View Postcan't, see my response to markbMichael "MP" Patrick (Deceased - R.I.P)
My understanding of all this is: they rotate their views instead of modifying the Project North...so when you link their model in its facing the wrong direction...if you try to compensate by moving your project north, the linked model moves too... And the reason they don't want to fix their model the correct way is because they already spent all their time rotating all of their crop regions..
I pray nobody in my office learns that you can rotate the crop region...Michael "MP" Patrick (Deceased - R.I.P)
Originally posted by MPwuzhere View PostMy understanding of all this is: they rotate their views instead of modifying the Project North...so when you link their model in its facing the wrong direction...if you try to compensate by moving your project north, the linked model moves too... And the reason they don't want to fix their model the correct way is because they already spent all their time rotating all of their crop regions..
Secondly, what's the problem with rotating a crop region? I do it all the time with duplicated plan views that are made into enlarged plan views. In my industry drafting convention is that all enlarged plans have the exterior facing down on a sheet. Only way to do that is to rotate a crop region for those plans that are not south facing. It doesn't have anything to do with the orientation of the model to North or True North.I'm retired, if you don't like it, go around!
I have imported a dwg into revit. It is at True north. When I rotate to Project North, the crop region also rotates in the floor plan view. In the site...November 29, 2017, 09:11 PM
If I rotate my crop region of a view to make something on a large site orthogonal to the view, such as a fence or property line, is there any way to "reset"...February 5, 2019, 08:40 PM
I was trying some things out trying to answer another thread, and noticed this behavior. Hopefully, my project isn't hosed.
When I rotate...September 10, 2012, 03:19 PM -
Is there a reason why when dimensioning to objects that are cropped by a rotated crop region these dimensions do not actually extend to the edge of the...August 16, 2015, 05:37 PM
Hello,
I have a filled region in a view with an edited crop region. Everything shows correctly on the sheet in Revit, but when printed to pdf, the...May 22, 2020, 02:38 PM
Monumetric Footer In-screen
