I know that most of you know this.... I discovered it a few days ago because I always kept my most wanted components in my template...
You can add families to the project directly from windows explorer, using drag'n drop...
This gives you some advantages...
1. Having bigger thumbnails than the ones in Revit dialog so that you can easily choose.
2. Having the search tool to easily locate the family if you know part of the filename.
3. Using drag'n drop you quickly place the family (drag the thumbnail to the revit view, push middle mouse button to make Revit window active and the explorer window hide, and you can place the family where you want).
