Divide
    Divide
    Hi
    I there a way to divide an arc into equal segments.
    I need to divide a quadrant of a circle into equal parts.
    Thnks
    The only way is a "radial array" of either detail lines or reference planes. A divide tool is greatly needed in Revit
    Mark Balsom
      Or you can use a string of angular dimensions, and apply EQ.
