To create a timber frame family, I need to precisely notch the timbers.
To control the dimensions with parameters, length, width, depth, there is no problem.
And then flexing the dimensions works just fine.
Now when I want to make notches in the extrude profile and control the sketch with parameters,
I get a "constraints are not satisfied" message on attempting to flex the parameters.
In this case setting 'a = 27' in the parameters properties dialog box.
And the only option offered is to remove the constraints. What should I be doing?
