Hi I was wondering if someone could give me a bit of help I want to edit the latent and sensible heat of a space generated by people from within a schedule. But when I click on the default numbers I am unable to change them. I have noticed when i click on the space itself and change it in the properties window from default to specified and enter a value it will update on the schedule. I am then able to change the undated ones within the schedule to a value of my choosing but am still not able to change the default ones. Does this mean i have to go into each space individually from the plan view and change the property from default to specified and enter my values instead of working within a schedule? Any help would be greatly appreciated
Sensible & Latent heat schedule
Hi all,
Im not sure if i can do what i want to do, i have been playing around with it and not having too much success. I will try to explain the...February 12, 2016, 01:26 AM -
Is there a way to have spacing between groups of mark numbers in a multi-category schedule? I have a schedule that is sorted by the Mark number. But it...October 25, 2012, 04:24 PM
Is there a way to scale a schedule. I'm trying to place my BOM in a 11x8 sheet but the schedule format is to big so I would like to resize it.
...January 8, 2016, 05:35 PM -
I have an "Electrical Connections Schedule" I'm working on. Type Mark is the first column. I have Marks E1 through E38. At E26 I have... E26-A...March 14, 2016, 04:18 PM
Is there a way to combine V/Ph/Hz as one header, and the three separate Parameters be formatted below the Header in a Schedule? I don't think there's...
Channel: MEP - General
May 31, 2013, 07:38 PM -
