How are you guys setting this up? I'm currently thinking that MasterFormat division number is the way to go for parameter groups, with 01 General reserved for 'Universal Width', 'Universal Length', 'Universal Height', etc.
shared parameter organization
I've had numerous setups, but I like the easiest best: just by parameter category: length, area, number, so on...
Why? ANY other setup I worked with sooner or later had redundant SP's in it. When creating a new Door, is the Frame Width not the same as for a Window? And so on...Martijn de Riet
Currently I have a 'stud length' instanced parameter which works great for stretching my studs after being loaded in another model, however I can't figure...December 22, 2014, 06:38 PM
There is no preference applied to one over another. A Shared Parameter is no different than a Project Parameter... a parameter is a parameter. How they...
Channel: Blog Feeds
January 20, 2012, 03:15 PM -
I was just messing around with a family. I started out with a Generic Model, added a shared parameter (Depth) and then decided to switch my category...
September 24, 2012, 05:46 PM -
Since there is no unit available in Revit for Sones, what type of shared parameter do you guys use? Number, Integer or Text?
Channel: MEP - Family Creation
December 10, 2014, 10:00 PM -
hi
I would like to add a number to the description parameter which is automated from the length. i can do this but in addition i would like...-
January 8, 2013, 05:26 PM -
