Hi all,
I am creating a stud frame family comprised of nested components such as steel studs, track, sheathing board, insulation, and exterior finish. I have no problem in building a rectangular assembly of these components; however, I wish to cut a diagonal swath through the assembly to show the guts for presentation purposes.
I have tried to do this by using a void extrusion through the panel and it actually cuts the components which were extruded within the family that the void is in; however, it does not cut any of the nested elements?
I have also tried this using the cut tool; but not sure if I understand exactly that this is supposed to work.
Any suggestions?
Thanks,
Jerry
Any suggestions?
Thanks,
Jerry
