split face for "me" is still one of the better ways as when you flex the roof capping moves with it . Splitting faces is a pain "but you can use mirror" see my recent post which speeds things up a bit.
Otherwise there is the 2 roof system looks great in 3d and rendered but just as much a pain to do and takes a lot of constraining to get the 2 roof to flex together, check example Roof file, select cap to understand.
I have tried just about every option ever devised but they all fall down on the joins. Has been a huge wish list item for me for ages. Our foreign counterparts probably don't quite understand the % use of corrugated iron roofs in OZ.
I will watch this thread in anticipation just in case there has been some innovative brake-through
Would it work to offset the same roof a few inches , change the thickness of it and to leave the caps use a in place void that cuts out the rest of the roof?
Hi Juan, that is the same principal as I was talking about in post #2 the "2 roof system" except with mine you just draw the roof (capping) lines. Both systems acheive the same result, but both are time consuming , and in mine to get the whole thing to move together you have constrain the top roof to the bottom roof and then constrain the 'capping" lines to the ridge and hips.
It does work. but as approx. 70% of my work is metal roofing I wish there was a better way.
I tried this for a rendering and it was nice...
I make a roof, I copy this roof with a small offset distance, like 10-12cm for example, and I make the new roof as glazing, using empty system panel and I use mullions to make the height difference. See attachment... the last image is the rendering from that project...
I made a roof with a roof cricket made up of two roofs. The main roof is a standard sloped roof that slopes down to the roof cricket roof which I made...
I've got an issue on a job where the two roofs refuse to join. The main roof was modified and after the change the dormer roof will not join. The only...
