Let say i have a box as a adaptive family that has a base, a rectangle. In the middle of one side of this rectangle i have an adaprive point. Just one. In the project, in the plan view, i draw a circle (model line). Is there a way when i create a instance so the box family auto align as tangent with the circle using just 1 adaptive point? i`ve used all the orientation options in the adaptive point menu but it doesn`t behave different in this particular situation. With 2 adaptive points is easy (just draw a radial model line on that circle and place fist point at the intersection and the second on the radial line). But i just want to abuse the Orientation function of the adaptive point. Is it possible in this situation?
Radial Orientation with 1 adaptive point
are there any ways to fixed this point to green and red axis?You do not have permission to view this gallery.
This gallery has 1 photos.July 23, 2021, 11:26 AM -
just thinking if it's possible to "host" 2 points from GM line based into 2 adaptive points from GM adaptive?
did a few tests,...July 20, 2015, 09:07 AM -
Hello all.
I have an adaptive family that deals with Fire Egress Length. I had originally wanted to allow 3D cartesian space manipulation...January 13, 2015, 08:31 AM -
Hi, everybody. I have a two point adaptive component, which shall serve as a rig driving multiple adaptive pipes surrounded by concrete. In order to do...
Channel: Structure - Family Creation
September 25, 2017, 10:11 AM -
Hello,
This is regarding adaptive components....I am just trying to figure out how can one ROTATE an extrusion created using 5 adaptive points...February 25, 2016, 10:33 AM
