Does any one know if I can nest a detail component into another detail component, and then load it into a project and have a tag that references both components in one tag
Example
I want to create a Concrete Footing based on typical sizes we use and the typical reinforcement required.
So I created two families (Detail Components) and some family types for these
One is the reinforcing bars in section (a circle w/ a solid fill)
the other is the Concrete Footing w/ the reinf. bar nested into it
I want to insert this family into a project and when I tag it I want it to tell me the type of concrete footing that it is ex. 12" x 16" Concrete Footing
and also the bar that is in there reinforcing the footing ex: #5 bar cont. reinf.
So the label should read 12" x 16" Conc. Ftg. w/ #5 cont. reinf.
I'm probably going about it the hard way so any suggestions are welcomed
Example
