Air Flow connector config
    I am not sure how to configure the intake and discharge connectors for this unit, which has no blower. The air flow (cfm) and static pressure (in-wg) will need to come from the system the unit is connected to, so would I use a "preset" flow config for both intake and discharge? Or would I link a formula to the "pressure drop" and "flow" to assume the vaules of the entire system?
    Thanks in advance
    http://www.captiveaire.com/
    Commercial Kitchen Ventilation Systems
    I'm not too familiar with the 'air flow' side of things, but I encountered a similar problem with a piece of piping equipment.
    Check out the attached pdf. It may help.
    Say something interesting....
      Thank you for sharing Gabriel. This info is a welcome addition to the reference library.
      • Air Terminal Flow Halved - two connectors.
        Hi all,
        Am I doing something terribly wrong?
        I've received a project with an Air Terminal family that has two connectors.
        August 12, 2015, 11:02 AM
      • Extract fan sdding up airflows incorrectly
        Hi good people of the internet. I have a problem with an extract fan I have sent to a client and am unsure of why it is happening (mainly due to the...
        April 26, 2016, 12:44 PM
      • Heating Flow Direction!
        Please can someone help me as I just cannot figure this out. I have got several radiators all piped up, I have been following the flow rate through the...
        September 14, 2016, 07:52 AM
      • AHU mixing section
        Hi all!
        I am interested is there any way to properly define connectors on AHU so that Revit calculates flow correctly? Please see image for...
        March 9, 2016, 07:00 PM
      • Flow to a Fan coil unit
        In a job we are doing, we are putting Fan coil units with supply air blowing into the back, so the supply duct doesnt actually connect to the unit....
        March 19, 2015, 11:13 PM
