Hi everyone,
certainly because I learn something with Revit every day I work with, I found this tip, certainly already known by some guru out there....
It deals with tags and parameters.
Depending on the family it deals with, you have the right to double-click on parameters in tags in a view, so that you may change them.
Following pictures will show you that column doesn't act like doors or walls.
Some categories allows you to directly edit type, instance or shared parameters in a tagged view.
Check pictures and feel free to comment, Gurus!:thumbsup:
:wine::wine::wine:
:wine::wine::wine:
