RMEP DVD set
    RMEP DVD set
    do you have a recommendation for a DVD set or online for learning RMEP? Your reply is most appreciated.
    Hi
    I recently purchased a Revit MEP 2012 DVD tutorial set from CADLearning. I'm about half way through it. It certainly helps as each subject is in video bursts of 2-8 mins. If you don't quite understand it, you simply replay it.
    Autodesk Revit MEP Tutorials
    Another good Tutorial package is from WhiteFrog Publishing (Home). They have Revit packages for Structural, Architectural & the MEP versions. I purchased the training manual including the dataset examples from Excitech (Building Services/MEP Training > Autodesk Revit MEP 2012 Fundamentals Revit MEP 2012 Fundamentals). If you attend the 3 day certified course it will cost you £885.00 GBP plus VAT. The Revit MEP Delegates manual cost £70.
    Trust this helps
