Topo view in 3D
    Topo view in 3D
    As attached,
    I wanna show the earth sign below actual ground level.
    Is there any option to show like what we can do in Section?
    Thanks
    Use a "Section Box" check box is in View Properties. Adjust box to suit. Box frame does not print.
    Mark Balsom
      Oh!
      I think my question make you confused
      sorry!
      What I want is to extend the visual of the Topo graphic down to the deep below as shown in attachment.
      Cuz In section view, I can add by using the option to deepen the cut surface hatching.
      I just want to be the same as section.
        No. The only way is to use the "Section Box" like iI said above.
        Try it and see if it gets you the effect you are after
        Mark Balsom
          What Mark B said... See the illustration below.
            Wow!
            Really amazing ....
            Very very thank you for your great guidance..
            Now i got it perfectly.
            Many many thanks to both of you .
            P.S .. now my perfect dwg is as attached.
              Hi, is there a way to permanently display the hatch with the "section box" unchecked? Every time I use the section box to crop into my surface and display the earth hatch and then uncheck the box it goes away. Rather frustrating.
                Nevermind I figured it out...just used the "hide in view" option to get rid of the section box.
                  Originally posted by Yan Naing Bo View Post
                  Wow!
                  Really amazing ....
                  Yan, can you describe the process, i tired but could't do that.
                  oh, its very simple, section box limits must be cutting through topo to show depth.
                    Unchecking the Section Box parameter in the view properties effectively deletes the section box. Checking again resets the box to the extents. Once the box is checked or turned on use the views visibility settings ( Visibility Graphics ) to control the Section Box visibility. It's a "special" element.
                    ~Erik
                    Erik Snell, P.E.
                    Factory Worker (Principal User Experience Designer)
                    I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
