Calculations of Cut/Fill on toposufaces seems to provoke me....
I Want to see Cut/Fill using graded region and Building Pads. I works perfect in this workflow:
1. Create Topo in Existing Phase.
2. Use Graded Region on the Existing topo.
3. Set Phase Filter to Show Complete to only see the result of changes to the topo.
4. Split Surface around the Property Area to track the changes for the property only.
5. Create the Building Pad
In this Workflow it works fine, I get Net Cut/Fill of the Property Topo and the Topo of the Building Pad. Exept when the split for the property is at the edge of the total Topo.
My challenge is when the existing topo contains Regions, the Net Cut/Fill does not show. The workflow as this:
2. Create Split Region
3. Use Graded Region on the Existing topo.
4. Set Phase Filter to Show Complete to only see the result of changes to the topo.
5. Split Surface around the Property Area to track the changes for the property only.
6. Create the Building Pad
In this workflow the Net Cut/Fill does not show.
Anyone having the same issues??
