I'm putting together a set to bring to the Department of Buildings and they require a volume diagram of the building which shows the volume in axonometric form. Considering that I already have the building modeled through CD, what would be the best way to achieve this diagram?
Volume Diagrams
Make a Design Option Set Called "Volumes" with two options:
1. None (primary)
2. Volumes
In option 2, go Ceiling- Auto Place, and place a ceiling in every room. Make a ceiling type that is the entire height of the room (a 9 foot thick ceiling). Youll need a bunch of ceiling types depending on how many different room heights you have. Materials and/or Filters can color them by use case.
Its not a great system, but its quick, and it works, and the DO keeps them out of your business.
hello
i've got a space with several heights ceiling (1,2 and 3)
how can i make one and only on space?
Phil
...January 31, 2019, 08:15 AM -
I'm looking for a little advice on the best way create some ceiling coffers (soffits?) - basically wood beams with trim on them around the room (see picture.)...October 5, 2012, 07:32 PM
Hey everyone,
I am having trouble showing ceilings and room tags on a floorplan. The Room upper limit is higher than the ceiling but as I...September 12, 2016, 07:26 PM -
We have some rooms that have automatically found the ceiling height, but others that don't. Is there anyway to force revit to recalculate the room heights...February 27, 2018, 02:32 PM
I am trying to get the ceiling(s) in each room. The GetSurroundingElements node is a great start, but it seems to be getting every ceiling even close...
Channel: Dynamo BIM
August 26, 2020, 07:10 PM -
Monumetric Footer In-screen
