Guys,
I have a ground slab that I would now like to reinforce. We usually use standard size sheets of mesh (with a lap) and place them around the slab area. Is there a way of modelling this in Revit?
I've had a look and there is nothing in the Extensions and the only other way I can see is to draw each rebar line or to use area reinforcement. If area reinforcement is that way Autodesk has intended us to do it then how do I produce MTO report for that area rebar.
Thanks in advance.
Thanks in advance.
