Help before I waste more time. Is there anyway to get a generic annotation label to be always vertical.
Generic Annotation Always Vertical
This topic is closed.
check off "rotate with element"?Martijn de Riet
I thought "rotate with component" was for Tag families, I am not really sure it does anything for straight "Generic Annotation" Families
I am not sure if there is a built in way to solve this problem, but one way may be to nest in the text element as a separate Generic Annotation family, then all you need to do is place one for each orientation of the family, you can then control which label shows with a visibility family
It would require manual adjustment for each placement, or you could just make two types if that is easier..
I don't get these kind of quirks. Why put the check in, if it doesn't do anything??? So make it work, or delete it all together...Martijn de Riet
Originally posted by Ben-May View PostI am not sure if there is a built in way to solve this problem, but one way may be to nest in the text element as a separate Generic Annotation family, then all you need to do is place one for each orientation of the family, you can then control which label shows with a visibility family
Tried this approach but seems clunky. "Always vertical" seems like a simple request for annotation ??Mark Balsom
Edit: Moved this thread out of the Wish List forum! Mark has created a new thread with the new formatting. I don´t like to delete a thread... so this...
Channel: Out There
March 8, 2011, 10:40 AM -
Applies to: - All Verticals
New Feature / Problem:
I feel there is a need for "orientation control" over generic annotation....-
Channel: 2011 Archive
March 9, 2011, 09:01 PM -
I want to make a simple label but I cant edit it. What I am trying to do is create a 'warning triangle' but I want a space inside where I can put a number...May 14, 2015, 11:43 AM
In a model with a project linked in. The linked project has a component with a generic annotation nested within it. Go to VV > Revit Links > Annotation...July 1, 2013, 07:13 PM
I have created a generic annotation, and assigned it to a plumbing fixture. However when I connect the cold water to the fixture, it automatically changes...
Channel: MEP - Family Creation
July 18, 2016, 01:23 PM -
