Is there a trick to annotating nested components? I have a family for an ADA toilet with grab bars nested into the toilet fixture but when I try to tag in my elevation it only seems to read the plumbing fixture host (bars are specialty equipment.) Should they be two seperate components?
Annotating nested components
It wasn't shared. I changed that but it didn't seem to resolve the issue. My guess is the different category types is the issue but I don't know... In your instance they are all plumbing fixtures. I have the SE and the plumbing in one family. :banghead:
EDIT - I can tag independently in plan, but not elevation.
Edit 2 - I'm an idiot and didn't set the vertical bar to shared :hide: it works now. thanksLast edited by cellophane; February 15, 2012, 04:27 PM.
It's not so much a "trick" but more a method.... if you want to correctly tag a correctly-categorised nested (shared) family then it's either a case of using the tab key to reach down the host family's throat to get at "it" but if you've a lot of items to tag, that can get pretty tiresome.
I tend to use (any combination of) filter selection, vg and/or filters, to show/hide items I'm going to want to tag, tag them, then reset the appearance of the view for output (or switch to another filter/vg-setting/selection set to tag other things)
I have a a pile cap with a pile nested into the family.
I have then inserted this into a project. I want to tag all the piles in the view,...September 12, 2013, 10:38 AM -
Basic question.
Family one is a flat plate with studs on it call it CHILD ONE.
Family two is a concrete panel call it CHILD...-
July 10, 2011, 07:42 PM -
Hi, this may seem primeval to some. I have been using Revit for architecture but now, transgressing into BIM, I need to understand how a nested family...November 13, 2014, 09:10 AM
Quick one:
Can I tag all shared families in view?
I have a family with nested components that I want to tag. I know that tab...March 15, 2017, 09:15 AM -
This thread is the result of further investigations after being unable to control the visibility of shared families nested 2 levels deep (described in...
September 17, 2014, 09:40 PM -
