[All Verticals] - Assemblies/Views onto "normal" Sheets
    Applies to: - All Verticals
    New Feature / Problem:
    Be able to place Assemblies/Views onto "normal" Sheets.
    Currently Assemblies / Views can only be placed onto "special" Sheets which are soley available via the Assemblies tool.
    We need to be able to place Assemblies/Views onto "normal sheets" containing related views, schedules, etc. instead of ONLY being able to place them on "Assembly Sheets".
    This is just too limiting in our ability to put together and compose a set of drawings.
    Workflow:
    1. Create an Assembly.
    2. Check all "automatic" views/schedules/etc. via the Assembly Tool.
    3. Drag/Drop any/all of these Views onto ANY Sheet in the Project as required.
    Benefits:
    More flexibility in placing Assembly Views onto any Sheet in the Project.
    Removes current limitation of ONLY being able to place Assembly Views on Assembly Sheets.
    Attachment comments:
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
    Not that I really "can't live without it", but it's one of the things that make me not want to use it until it get's fixed. It's just plain stupid, makes the whole assembly thing a useless piece of ****... <Rant off>
      Totally agree! they must fix for the next version!
        Looks like your wish came true....
