Worth an echo. Ryan at The Revit Clinic wrote an post this morning that lists the order of power, the pecking order, the order in which visibility settings and override tools stack up...who wins when multiple things are applied. Good info, check it out! Here's the list...you need to read his post to get the graphics.
(10 is the lowest and 1 is the highest, using walls as an example)
- Line Work Tool
- Override Graphics in View > By Element > Halftone
- Graphic Display Options – Silhouette Edges
- View Filters
- View Depth – “Beyond” Line Style
- Phasing Graphic Overrides
- Visibility / Graphic Overrides > Override Host Layers > Cut Line Styles
- Visibility / Graphic Overrides > Projection \ Cut Lines
- Project Object Styles
