Load from type catalog of a different family?
    I renamed and significantly modified the default framing wide flange family for some structural detailing. Now I realize that I'm lacking a shape that I need. Is there any way to pull the type from the OOTB family type catalog?
    If their parameters are named the same, you could be lucky: copy and rename the other type catalog to the same name as your new family (put into the same directory) and see if it works
    Alex Page
    RevitWorks Ltd
