revit wall.jpgrevit wall error.jpgI am modifying a existing wall type: 90mm stud. When I add the "finish" on either side, I get this message: Extension Layers at the base of the wall must be adjacent. What does this mean???????
Wall: Error
That´s probably because one (or more) of the layers in the wall style are unlocked... While in the wall properties, and the preview is set to "section", click "modify" and zoom into the bottom of the wall, click the horizontal lines at the bottom of each wall layer, and check if one (or more) of these are "unlocked" (the padlock)
Unlocked layers must be adjacent to one another :beer:Klaus Munkholm
I know its a workaround but if you unlock the center (structural) wall you will get the desired effect.You will notice in properties base offsets it sort of works on reverse.Last edited by mark b; February 7, 2011, 11:11 PM.Mark Balsom
Hey guys , I am having these two problems:
1- tiles alignment with wall I cant edit those
2- after adding plaster to the wall it...December 15, 2014, 08:07 AM -
okay try this: open a new project- (default template or no template)-o
draw a piece of wall- go into wall assembly and add a couple of layers...February 14, 2012, 03:07 AM -
I would like to ask which is the actuall wall thickness according to the construction in a GBXML. For example if a wall Construction has layerIdRef=&...
Channel: Coordination Tools
March 30, 2012, 09:37 PM -
Hello!
I am creating a wall with multiple layers. The wall is consisted of layer with mineral wool between wooden substructure. How to show two...June 18, 2014, 10:37 AM -
Hello friends,
I've successfully wrapped the exterior layers of my Wall to the Reference Plane/Wall Closure created in my window family....November 21, 2019, 07:17 PM
