Hi, I have imported a cad model, I am trying to make 3 sweeps along the 3 lines shown on the attachment (the profile can be seen on the left) How can I make a reference line along those 3 cad imported lines? I am unable to snap to the line and when I select the line to make reference or model line it just moves it to the set work plane. As you can see the lines are sloping both horizontally and vertically. I just need to trace over these lines and I cant figure out how. Im sure its something easy I am missing? Regards JP
Re - Concept mass - Reference Line from CAD
Originally posted by Dimitri Harvalias View PostYou can create an adaptive component that you can 'snap' to the path. The number of points required will be determined by the nature of the curve. (hard to tell from the image).
Your AC can either be the path for your sweep or it can contain the profile as well.
I was having trouble snapping to the path but I will split the cad lines up and try give it another go.
JP
Is there a way to import cad lines keeping their properties, or importing line types from cad into revit? I know i could create all the lines i want but...April 15, 2014, 07:32 PM
Hi There
Is there any way to make the CAD files line sit beneath the Revit lines when linking a CAD file.
We have the ID work...May 10, 2017, 05:29 AM -
How would I import a CAD drawing and convert it to a line drawing in revit? I want to import the CAD drawing and take call outs from it. When I import...November 19, 2011, 11:07 PM
"Revit ate my dimensions to my CAD file!"
These type of threads having been going on for years. Best practice I've pushed down...August 4, 2014, 05:21 PM -
I am creating hybrid (2D/ 3D) door families for a large project with dozens of custom door and frame types. To do this I imported portions of CAD drawings...November 6, 2012, 09:37 PM
