How to Redirect Libraries Folder Location?
    Hello everybody, I’m new to the forum and I’ve got the following question:
    Is it possible to change the location of Libraries folder or parts of its contents?
    By default it is located under ProgramData in the same folder as ‘Family Templates’, ‘IES’, ‘Recent’ and ‘Templates’.
    The folder is quite large and I could make good use of additional disk space on my C drive.
    I’ve seen options for other directories in the File locations tab, but not for the default libraries. Would it be possible to get there through entries under the Places button?
    Thanks for your help!
    If you click the places button it will open up another dialog box and you can set it there.
    chad
      Thanks a lot cellophane! I suspected, that I could do so, but I wasn't sure since it was a system library.
        Just make sure you move the library that you want to be the "default" library to the top of the list. That's the one that will open when you click the Load Family button.
        Arcturis
        BIM Manager
        Associate Architect
