Hi all,
This is beyond me (unfortunately). I have a door family with nested frames. All good.
The frames have different throat widths and as such the door panel must adjust to sit within the frame as they are being selected. I am using a shared parameter to change the frames in the family (label).
What i want to do is create a parameter in the parent door family, to place the door panel in the correct location according to the frame type seleccted, i am asusming this can be done with a conditional formula???
Is this possible???
Basically if the frame type = Fr1 the panel offest should be XXmm, FR2 the panel offset should be XXmm and so on.
Any help appreciated.
Is this possible???
