Hello all
Title should read "Conc Stairs wont join SOG (Slab on Grade)
I have created a small set of conc. stairs using OOTB method. I have checked all possible spots for the material and the stairs and sog are the same material but i still cannot join the two objects. I stairs will be poured with the slab.
Is there someplace I am not looking or do I need to create a family for this.
I have checked the materials for both objects thru the properties and the type properties.
Or is it because revit treats these two elements completely separate.
