Hi Everyone all of us Know the usage of pointed arch especially in religion buildings. The forum covered the arch (curve one) What about arch one?
How can we produce pointed arch parametric ?
If both A, H & R are controlled by manual input, you can construct it with simple ref. planes and ref. lines.
And having done that already, it would be simple to throw in some formulas for equilateral archs etc.
Example of equilateral arch:
A = R
H = A * sin(60°)
Note: If you only need a equilateral arch, it'll be much simpler to just layout a equilateral triangle, and use that for the base.Klaus Munkholm
Originally posted by Munkholm View PostExample of equilateral arch:
A = R
H = A * sin(60°)
so is this formula to make half of arch is equal to the another half arch.
Originally posted by ahmed_hassan View Post...so is this formula to make half of arch is equal to the another half arch.
The formulas aren't needed at all, the only reason I mention them, is that geometry like that is often based on some rules of thumb. Like "The Height should equal 1½ times the Width" (Or whatever...)
Formulas could also be used to ensure that the family don't break with certain values (The above family will break at certain conditions - Like if the radius is to small)Klaus Munkholm
I have some arched soldier courses (wall based family) and I need the material & hatching to follow the arc. I can create a new image map but I'm...July 6, 2012, 08:33 PM
Hi, i have like this arch with the rectangle below
the width of the window is = 1.7 in the picture 1
now when i change the width to =1.4...-
December 3, 2011, 04:48 PM -
Anyone out there have a good rule of thumb for making MEP content show up nicely on Linked Arch file. When we go to plot and click on replace halftones...
Channel: MEP - General
February 13, 2012, 07:44 PM -
Hello everyone. This is my first post. I'll get straight to it. I have 2 issues trying to create the following family. I'm trying to create a parametric...
August 19, 2011, 05:34 PM -
hello, i wanted to ask how i can parameterize arches/lock them in ref planes?
ive been trying to create a garage but when i adjust its height, the...-
February 16, 2013, 09:27 PM -
