I put a wall plate in the model and want to tag it,but I can not find the structual coonection tag from the library.Does any one know where to find it?
Where can I find stuctural connection tag?
Here you go. I could not find one anywhere though I know somewhere I have made one.
Looks like you just have to make a Generic Tag and then switch it to Structural Connection Tag once in the family editor under Family Categories and Parameters. This just tags the Type Name right now, but you should be able to manipulate it how you need.Attached Files
When tagging items, I see that Revit uses the current tag allocated for the Category as defined in the Loaded Tags and Symbols dialog.
I...July 15, 2021, 07:11 AM -
I am trying to tag my structural elements so that If I ever need to change them, I won't have to change the annotation. My problem comes when I have something...
May 13, 2013, 06:37 PM -
What kind of setting is responsible for this behavior? When the leader consists of only one line the tag is placed in the same angle as the material,...July 4, 2011, 01:12 PM
It is pretty common to have quite a few different kinds of tags for the elements we need to tag in views. Some equipment might get an oval shaped tag...
Channel: Blog Feeds
August 6, 2014, 01:45 AM -
So I imported a family from Knoll and am trying to remove the tag that came with the family. It's built into the parameters somewhere but I cant for the...October 19, 2016, 08:13 PM
