Issue
You want to update a revision/issue title block label globally in multiple sheet views without the need to edit every single individual sheet view.
Solution
The following steps explain how to add a label to a titleblock, which can be updated globally in multiple sheet views.
via
Autodesk - Autodesk Revit Architecture Services & Support - You want to update a revision/issue title block label globally in multiple sheet views
Solution
- Create a shared parameter in titleblock
- Add label into titleblock
- Load title block and add parameter into project
via
