Anyone knows how to get rid of the aprox. ½" setback, that apears on topo´s when cutting it with a section box ? This has been bugging me for a long time, and I´ve not been able to find a solution... maybe there just aren´t one ? :beer:
Topography Surface / Section Box ?
This topic is closed.
when you cut with section box your geometry and you go to an axonometry and zoom in to a geaometry(fundation) you will see that the cut plan of topo surface is not coplanar with the cut plane of geometry. Looks like sectioned geometry is detached from the hatch of toposurface(in axonometry).
Originally posted by Chadwick17 View PostAlmost seems like that is be design to give the structure some 'pop' in 3D...kind of makes it stand out against the topo even though that is completely unrealistic
As attached,
I wanna show the earth sign below actual ground level.
Is there any option to show like what we can do in Section?...-
February 23, 2012, 03:30 AM -
I would like for my topo surface to have edges, as if the acutal ground were cut off. In otherwords, I would like to show a surface with volume as opposed...April 25, 2013, 12:48 AM
how can i do topography like this with thickness like this....February 28, 2013, 11:01 PM -
We are having some issues with section boxes creating odd geometry when interacting with topography.
See attached screenshot and link for...August 13, 2019, 11:30 AM -
I would like to create a section box that eliminates everything inside the box and shows everything outside the box. Does anyone know how to do this?March 30, 2013, 03:37 PM
