Nope...
Save as jpg and import that is the next best thing.
IF your PDF has vector information (such as if it were saved or printed from AutoCAD), then you may be able to extract that information using Ghostscript or Illustrator - links below:
Ok, maybe I should have said there is no way to get any reliable pdf to rvt conversion... :laugh:
And I was indeed assuming the pdf didn't come from autocad, cause that would mean that you could also use the dwg (unless you're not on speaking terms with the previous architect, owner or any of the other consultants working on the project)
I would not go through an image. An image does not really give you much to really go on. There are many programs that will export to dwg and dxf out there which at least allow you to snap and such to the lines opposed to an image.
Sometimes a user just wants to slap onto a sheet a manufacturer's cut-sheet, a page of specs, a sub's submittal, etc., and be on their way in the five seconds it would take to insert a PDF.
True, and exactly why I use images... Cause the freakin thing will also snap when the line is 0.0003degrees off, making it look straight and failing when trying to dimension two walls that are "aligned". Sorry, but a lot of wasted hours told me to never trust converted dwg's.
