Hi everyone just want to see your opinions and suggestions about this first interior rendering for kitchen
My First interior rendering Kitchen
Looks great! Couple comments.
I think the perspective is way too extreme. I know you won't be able to see as much but...
Also, some of the finishes seem a little too reflective. I'd try turning them down and getting them to be a little blurry (I think that means you need to add a slight bump but I'm not sure).Greg McDowell Jr
about.me/GMcDowellJr
Looks great for an first attempt at interiors! But have to agree with the above comments, especially on the camera distortion. I'd also try to make it less "yellowish", by either changing the color/temperature on the light sources, or simply by lowering the "White Point" in the exposure settings after the rendering have finished (Or a combination of both). Would also be a great improvement, if you change the sun settings, so that you'll get some hard sunlight coming thru the window at the back wall (at an angle).Klaus Munkholm
The cloud, I think, is using a different rendering engine (or at least a different version of Mental Ray). I've seen others talk about the differences between local and cloud renders. Some preferring the cloud, others local. Me, I'll take the faster renders any day and work with lights/materials/etc. to get the look I want.Greg McDowell Jr
From a purely functional standpoint I would adjust the location of your cans towards the cabinets, or centered between your counters. It will balance out the lighting some and will be easier to actually work in the kitchen itself. After that, readjust your grid so the cans are centered in the tiles. Right now you have cans sitting on the gridlines and it looks funny.
The rendering itself is really nice though. :thumbsup:
I was just exploring interior rendering in Revit.
In one of the rendering where i used Interior-Sun & Artificial...-
Channel: Rendering and Gallery
May 15, 2013, 12:34 PM -
I've been messing around with rendering on and off for a year or two. Attached are two renderings. Both are 150 dpi 4" wide. One is done on the medium...
June 10, 2011, 03:43 PM -
I rendered two scenes of a kitchen. One was done with the Draft Setting on the Rendering box, and No. 2 was done with the Medium Setting on the Rendering...
February 11, 2013, 02:28 PM -
Recently I have become the defacto rendering guy. It's a bit odd because I never considered myself much of a renderer and I would rather be designing,...
January 20, 2011, 03:50 PM -
This is a quick exterior rendering. 100% revit, no photoshop....
November 1, 2011, 08:40 PM -
Monumetric Footer In-screen
