Is it possible to have separate instance of doors if same model is copied twice (or more). I have same building in multiple places on the site and would like to tag each door as an individual door instance. How does Aaron handle this when linking multiple copies of same floor in multi-floor building?
Linked building multiple times - Door Tags
Hi Twiceroadsfool,
Could you please expand more on this concept? I have different names for each instance of each link in my project and have named the doors within each link as you noted (i.e. x02...). However, when I run my door schedule, Revit will still consider each door as one and not separate the doors into each unit. The picture attached shows that I have tried only for Unit 1 Lower Level and Unit 2 Lower Level, and I left some unique door marks in Unit 2 Lower level instance. Door Tags.jpg
Right. It will list ever instance of door "x01." Now, in the bottom left where it says "fields to choose from" (where it says "Doors") move that select to File Link. Then you can also schedule "link name" or "file name."
Using link name, you put it as the column before mark. You end up with
1 x01
1 x02
1 x03
2 x01
2 x02
2 x03
If you don't want to see every link turn them off in visibility/graphics.
With regards to Door Tags, I edited the door tag and edited the labels. I added a Mark (the door number) and the type mark (the door type). For both...May 4, 2012, 08:48 AM
Hi All,
I'm wondering if it is possible to create a door tag with text that can be editable without a parameter? I've tried creating an...-
February 17, 2017, 05:16 AM -
In my current project, I have a large range of existing (and identical) doors that are getting some new door gaskets (which I will cover with a remark...October 9, 2013, 07:56 PM
I am trying to find a way to have a list of door hardware functions as a pull-down from the door schedule. I want to use the ANSI Function Codes and Descriptions...June 21, 2019, 01:36 PM
:banghead:
I've been charged with implementing Revit in our office and am trying to set up our template files. One of the issues I have...October 26, 2011, 08:25 PM
