Stepped footing not joining with Wall footing
    So I have a family that I created and for some reason it's not joining with the wall foundation. It's a simple line based sweep with a profile in it. I can't seem to figure this one out. Do you have any thoughts?
    Here's some pictures.
    Stepped FTG - Cont.rfa
    Adam Hutchinson
    Engineer in Training
    Integrus Architecture, P.S.
    Just a stupid idea... does it have the same material applied to both footing families?
    BTW I hate wall foundations.
    Edit:
    Now that I loaded it I see what you mean. You cant even select it to join the two masses....
    -Alex Cunningham
      Ok.. It's because you used a sweep. I remodeled it at a extrusion and it works. :-\
      2012-01-25_1550 - Alex_Cunningham's library
      -Alex Cunningham
        Yeah, they do have the same material.
        Edit: So, because it's not an extrusion it doesn't join? Any clue why?
        Adam Hutchinson
          Yeah... ummm no. Gona have to let someone smarter then I answer that one. hahha
          Stupid IMO though.
          -Alex Cunningham
            Oh, and also, I went to change the visibilities setting of it from all visible to only visible in medium and fine, and now it wont join =(
            Adam Hutchinson
              Oh I wonder if that could be why... Seems more logical then sweeps and extrustions not joining.
              Uploaded a family to test against.
              -Alex Cunningham
                That's what it was. I have to leave the course check box checked but I don't want it to be viewable in plan so I guess I can un-check that box and it works.
                Adam Hutchinson
                  Take a look at the family I posted here:http://www.revitforum.org/architectu....html#post1660
                  Revit will Join Geometry with Course Level of Detail geometry only.
                  Erik Snell, P.E.
                  Factory Worker (Principal User Experience Designer)
                  I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
