Does anyone know where I can go to change the way my beam system looks in plan view? I would just like my beam system to have a little bit more of a cutback in plan. I would like it to be at least 1/8" to 3/16". I found where to change the beams but not a beam system.
Beam System Plan Cutback
AFAIK you'd need to change all the beams in the beam system manually... No way to do it for an entire beam system at once.Martijn de Riet
Well I like the way the beam at the column is. So if I get rid of the beam system then they will change all beams even the ones on the grid lines. Actually I am wanting the beam to be cut out where I have a beam tag. The lines of the beams going perpendicular go thru the tag and I was hoping there would be a setting that could fix this.Yep - It's me Again, and Again, and Again.......
Originally posted by sachez143 View PostWell I like the way the beam at the column is. So if I get rid of the beam system then they will change all beams even the ones on the grid lines. Actually I am wanting the beam to be cut out where I have a beam tag. The lines of the beams going perpendicular go thru the tag and I was hoping there would be a setting that could fix this.-Alex Cunningham
Like Alex said: create a masking region in your tag, or edit the tag type properties and change the value for from Transparent to OpaqueMartijn de Riet
Originally posted by mdradvies View PostDude, this is NOT autocad... Cutting back the beam means IT GETS SHORTER (yes, in your schedules). Cutting the beam at the tag means YOU GET TWO BEAMS!!!
I DID NOT want to cut the beam back physically.
I want to change the way it is displayed in plan view ( show a bigger gap from the beam it is framing into). Revit lets you change the gap on the beams to the columns with any gap distance you want, why not the beam system also (wether they are joists or beams). I just thought that there was a setting that I was missing somewhere.
If not, I will just change the beam tag.Last edited by sachez143; January 25, 2012, 02:25 PM.Yep - It's me Again, and Again, and Again.......
Ok, no biggie... Just wanted to make sure here... I suggest you alter the tag then, no other solution. And if I'm not mistaking: even in a beam system you can change the cutback for separate beams by tab-selecting them and changing the value...Martijn de Riet
Hi Guys
I have placed a beam system on a named ref plane. I have now extended the beam system and the beams dont extend to the end?...-
June 8, 2012, 08:41 AM -
Hi there, quick question:
So i draw this beam system and I want exactly 3 beams, two on the sides, one in the middle. But Revit places them at 2/5,...July 13, 2016, 02:40 PM -
Hi, I'm trying to create beam system but I have a problem...... I started with my first level I created all my beams systems and on my first level they...
June 26, 2014, 03:29 PM -
just starting dealing with BS, I was not able to put justification for beams as I wanted.
It seems that beams are always acting as if...-
March 27, 2011, 02:29 PM -
Hey guys. Could you help me?
I´m trying use a beam system to define a roof structure.
When i change the beam direction the beam doesnt go...-
September 23, 2014, 03:46 PM -
