Rotating Viewport - but keeping Title line in place
    How does one rotate the viewport, but keep the title line in it's original orientation (i.e. without it rotating along with the viewport ...)?
    Bryan
    "To make something foolproof is to underestimate the ingenuity of a complete fool."
    Bryan
    Unless something has changed, I don't think this is possible.
    A work around is to create a dentil component to look like yor view title, of course you lse ll of the automatic function when doing this.
    Andrew Harp
    BIM Manager GHD
      Thanks Andrew.
      Thought of something else. Going to set up the rotated view without a title line and then drag in another viewport with the viewport showing nothing and using it's title line. A work around (and an irritating one at that if one forget's that you've done it) but should get the effect.
      Bryan
        Originally posted by brinxb View Post
        Bryan
        Why not just rotate the crop boundary of the view? This will rotate the view to situate itself on the title block but will leave the title line alone. There area few glitches doing this, but I believe they are only with RST portions.
          That works perfectly - thanks.
          Bryan
