export wall projection to cad with certain color ?!
    How i can change this wall projection to yellow color from export setting in revit ? noting in our office standard we have wall cut =magenta ,
    wall projection =Yellow.
    so how i can make from export wall projection is equal color 2 because when i do that in export setting it effect on both cut an projection together take either color 6 or color 2
    6=magenta
    2=Yellow
    Wouldn't that be a window sill?
    chad
      i do not think it would be window sill because when i checked the export setting you will find all setting for window category take color 2 which is yellow.
      so i do not think it is window sill i think it seems wall projection (elevation of wall that is not cut) that i need to assign to it color 2 or so rather than the same color of wall which is 6 magenta.
        When exporting from Coarse Detail Level, the Walls/Exterior is what you need to set to the color of your choice..
        This being that Revit don't see what function the layers of the is set at, and only see a wall which is either Exterior or Interior according to the Function of the entire wall.
