Printing Halftone Text
    if i'm printing B&W and using Vector Processing, then halftone text (ie - room tags) linked into my MEP model will be print as solid black, how to solve it? thanks.
    Create a new text type with a greyscale color (100-100-100).
      text already in greycolor (128,128,128), is (100,100,100) magic number?
        You have to print grayscale or color to get gray tones. revit's print B&W is exactly that black or white, no grays.
          i tried print grayscale but turned out everything is printed in color, do i missed something here?
          seems print B&W is OK for all halftoned or greyed stuff except text, any magic for these text guys? i use Revit default Arial.
            Anyone find a solution to this? I currently have a request for halftone text, and it keeps printing black.
              Make the text type color (100,100,100) and print in with color not B&W.
              Rob Pivovarnick, AIA
              Senior Project Architect
              Michael Graves Architecture and Design
              LinkedIn Profile | @ Twitter
                Try creating a PDF first, then plot the PDF (instead of plotting directly from Revit). It might be an issue with the print drivers.
                Tony Perez @Twitter
                Senior Structural Designer
                Tesla Gigafactory - Austin
                  It was already set to print color.
                  Originally the user had just used override graphics to make some particular room tags gray, so I then tried making the text in the tags gray (color 100, 100, 100 was too dark; so I used 192, 192, 192), but had the same result.
                  I tried printing both a pdf and directly from Revit with the same result.
                  The user decided to go with a different graphic solution to show the information needed.
                    I had a cover sheet with a grayed out index. I had to be sure I only printed that sheet using Raster and Graytone....the rest were Vector and Black.
